It is currently Wed Jun 25, 2025 11:06 am
PostPosted: Wed May 03, 2006 10:42 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Warmoth sells gold fret wire (F61GD) that is not plated but is a copper alloy they state wears as well as their standard wire. The color is very similar to 12k gold.
The possible problem is that the wire only comes in one size--.90 x .055, which seems narrow and high. What about the use of these. To high, narrow, how to fix if necessary?
PostPosted: Thu May 04, 2006 2:40 am
Jescar makes all sizes in both silver and gold colored fretwire. Email Jeff
Silver and he'll set you up:
Jeff Silver
Jescar Enterprises, Inc.
213 Airport Executive Park
Nanuet, New York 10954
Phone: 845-352-5850
Fax: 845-425-1366
jescar.ent@verizon.net
PostPosted: Thu May 04, 2006 12:52 pm
I noticed that LMI also sells gold fretwire, just not sure what sizes...
PostPosted: Thu May 04, 2006 3:22 pm
The wire that LMI carries is Jescar wire (as well as Allied Lutherie), and the
advantage is being able to buy in smaller quantities. I don't know what
Jescar's minimum order is, I've only bought five or six pounds at a time
from them. They supply many of the manufacturers and prefer to sell in
skid loads of 30# spools.
The gold wire that LMI sells I'm sure is Jescar's "EVO" wire, which is at
least as hard as thier nickel/silver (which is the hardest nickel/silver
available that I've found). The Warmoth wire you mentioned is probably
Jescar as well - .090"x.055" would be thier 9662 size.
I'm not sure what sizes LMI stocks in EVO wire, but if you can't find it
anywhere, Jeff at Jescar is very helpful and easy to work with.
PostPosted: Thu May 04, 2006 4:55 pm
When I ordered from them a few months back 1 lb. was the minimum order.
